quote Garry in Tampa:
I posted the parts book and a diagram of the pump here a while back …
You sure did, Mr. Big Blue.. it’s just one page back. 😉
My apologies for the confusion. In this case, the Sportster water pump doesn’t use the part I described as an "intermediate plate". For those interested, it’s Johnson part #41-300,589. But it seems it doesn’t apply to the Elto Sportster, despite the other similarities.
If the prop shaft is turning, and the eccentric is following it, then there are only a couple of remaining possibilities. You have a blocked intake, a blocked output, excessively worn water pump parts (inspect & measure the internal surfaces & clearances) or you’ve failed to establish a solid connection from the output of the pump to the base of the motor, via the water tube, where the water enters the power head cooling loop.
Again, an extremely simple and reliable system with (effectively) one moving part. The rest is all down to seal quality and basic plumbing.. "got leaky pipes?" 🙂
