Home › Forum › Ask A Member › ELTO Timer and Coil
  • #6668
      Putting the finishing touches on the Ruddertwin.
      Went to restore the timer and found it broken inside. Typical and my luck.
      I have another model J, hopefully the timer on that one is good. What are the re pops worth?
      Also, opened up the coil, and instead of the usual black tar, found a white, almost concrete like substance. Hard as rock. Anyone found this before?
      #55557
        Just a secondary cap someone put in. Had not seen that before. Almost like a concrete board. I had to drill it out but its done now.
