Home Forum Ask A Member Eska fuel connector question
  • #184895
    Doug Wilson
      I know they are not popular but I am working on a 7hp Eska for a friend the question I have is it the same female connector that was used on the smaller 6hp Chrysler in the early 70s
      they look to be real close.
      Doug
      Doug
      turned off?
      #184900
      russ
        Doug. They are different. Found this out myself just last week. Took the fitting off an old Eska for my old Chrysler and it would not work.If you have one from the chrysler check the push pin inside the fitting they are a different size. They look close but not quite close enough. Not an expert on this subject just letting you know my own experience.
        #185004
        Doug Wilson
          Thanks for the response I had tried the chrysler hose and it seemed to fit but then acted like it was puling in air and would not keep running.
          Will track one down that fits.
          Doug
          Doug
          turned off?
