Home Forum Ask A Member evenrude MN 4307-0218
  • #183019
    KENNETH BROWN
      Can someone tell what year this engine is
      and how to get a coil. it does not have a spark
      #183021
      Phil Budne
        For model 4307 I get 1939 Elto Handitwin….
        http://www.omc-boats.org
        #183037
        Randy in Tampa
          Check the condenser, clean the points and check plug wires first,may not need a coil🤔
          Rotary valve Johnson’s Rule!
          #183039
            This may help – – – I have heard of an Army/Navy surplus coil that might work. I believe il was used on a drone . . .
            #183042
              Are you aware that both plugs fire at the same time? Testing for spark on one wire while the other dangles doesn’t get it.
              #183094
              KENNETH BROWN
                Thanks I will start looking into my no spark issues.
