" First shot most of the spray backed up  around my wand. I kept spraying and observing until I determined I had good flow thru the three
little holes by the throttle plate."
is it possible  you actually push any crud inside the idle chamber with your wd40  wand??
if the juice sprayed back  maybe the passage  to the idle chamber  was plugged and you  pushed it in the chamber .. wher  teh crud now  impedes fuel flow in the idle cct .
have you ever pulled the dime size plug to  "look inside " the idle drip chamber   ?
Joining AOMCI  has  priviledges 🙂
