Home › Forum › Ask A Member › evinrude 3,3hp 4423 lower unit
are these the only places that attaches lower unit to power unit? side bolt, dowel pin and rear screw? also any idea where to get the dowel?
thanks dave
thanks, you wouldn’t happen to know the specs on the drive shaft screw? 200709 thanks
See if a 1/4″ x 20 tpi threads in the hole……it’s the most likely.
