Home Forum Ask A Member Evinrude 3HP folding motor
Viewing 4 posts - 21 through 24 (of 24 total)
  • #219670
    cajuncook1
      I going to show a 1966 Evinrude 3hp Folder and the lower portion of the drive shaft linkage for the folder. My 1966 Evinrude 3hp folder is missing the coupler and the stainless steel clip, so I will borrow Chipster’s pic.
      0383F743-3682-4E30-8579-FE7DCAA1552C
      6D00C142-AFD0-4A43-BC5D-F21F4604141A
      • This reply was modified 4 years, 3 months ago by cajuncook1.
      #219676
      cajuncook1
        This motor is my 1967 Johnson 3hp Folder. It has a coupler that a rim and a washer to maintain its position on the lower portion of the drive shaft assembly.
        096F0278-92AD-45E0-B951-87C1C7539D1F
        5659351F-FB27-490D-98DB-A3F6B97A51AC
        CE4BE45D-DD02-429F-8994-9FEE5BAAF9AD
        #219681
        cajuncook1
          This motor is my 1968 Evinrude 3hp Folder. It has a coupler that has a rim and a washer to maintain its position on the lower portion of the drive shaft assembly just like the 1967 Johnson 3hp Folder.
          So, it looks like the 1965 and 1966 Folders have the couplers with the stainless steel retention clip and the 1967 and 1968 have the coupler with the rim and the washer. I would assume the 1969 4hp Folder would have the same set up as the 1968 3hp Folder.
          B3A37BCF-9FED-44D1-80B4-F3CF3D4FE6EF
          4740256D-A269-4741-A0E2-6BB7F72D75E3
          0E0601F7-1229-4158-8336-C3FE2CC40395
          E4E13203-09B2-43C2-BD89-472EBA3CC263
          #219692
          fleetwin
            US Member - 2 Years
            Thanks! Makes sense now. The new style uses a coupler with a lip at the bottom…Put the washer in place, push the coupler down on the spring, then push the pin through….Sure looks like a better design than the SS retainer clip…I’m sure the newer style components could be used on the 66 models as well… You have got a nice collection of folders there David! I have a 68 Lightwin, but it is a “rigid” model…
