Home › Forum › Ask A Member › Evinrude 40454S 1974 40hp mag plate and boss wear
- This topic has 12 replies, 6 voices, and was last updated 6 years, 8 months ago by
vintin.
June 15, 2018 at 11:41 pm #78017quote Dan in TN:Somebody in the club has to have Seavice Bulletin set from that time? The information is in the form of a SB. Should be around 1976/77. OMC was having enough trouble by then to offer the kit. I believe it was called a Stator Stabilization kit. It changed the way the mag plate bolted to the top of the block. No longer uses the top collar at all, just like the #580871 kit, but mounting holes for low tension stuff & charging stator.
Dan in TN
Thanks Dan,
I found these service bulletin numbers but not the bulletins themselves.1425 Armature plate bearing improvements and lubrication on 1974 thru 1976 – 9.9, 15, 35 & 40 6/76
1445 Armature plate improvement kit on 1973-1976 – 20 & 25 8/77
1488 Armature plate and pilot replacement kit on 1974 thru 1976 – 9.9, 15 & 35 1/79June 15, 2018 at 11:48 pm #78019quote FrankR:quote VinTin:Frank the bearing shell looks to also be of brass.Really?? Are you sure it isn’t brass wiped off onto it? See if a magnet will attract to it. I think it is the bearing, but could be wrong.
Frank is right!
Brass has been wiped off onto it. The magnet attracts to it. It does look to be a part of the bearing.
There is a small brass sleeve pressed into the aluminum ignition plate. I assume this is the way it was manufactured. This brass sleeve rotates on the steel boss on the top of the block which looks to be a part of the upper bearing. It is likely only this pressed in sleeve that needs to be replaced. There were a lot of brass fines on top and around the lower steel boss.
I was tired of this motor’s recent poor running and decided to pull the flywheel and look around. As I was getting the strap wrench on the flywheel I moved the flywheel slightly and saw the mag plate move. I knew right then that the problem was under that flywheel. I believe it was rubbing and jerking the mag plate resulting in very erratic timing advance and erratic performance.
June 17, 2018 at 3:13 am #78066quote FrankR:Doesn’t that brass sleeve rotate around the hardened steel bearing shell? If that is correct (?), the steel should not be worn and a new armature plate should restore it.EDIT: Bare armature plate was part # 581217, NLA
Frank do you know anything about the number of 581217 supersedes up to 582067?
Will either part number will suffice?
Also about this ignition plate:
Dan brought to my attention that there is a new driver coil part number…..#581130 Echlin brand Vs
OEM 0763784. Ask the guys & see if they know why there are two numbers? -
