Evinrude 5.5 Fisherman Power head Main Bearing oil hose
Home Forum Ask A Member Evinrude 5.5 Fisherman Power head Main Bearing oil hose
Currently, there are 0 users and 1 guest visiting this topic.
  • Avatar
    rudefan29070
    US Member - 1 Year
    Topics: 12
    #208061
    Hello All,
    I’ve been working on this little 1963 Evinrude 5.5hp Fisherman. My main bearing oil hose Part# 0303463 is broken and brittle and it is unavailable. Does anyone know what size hose this may be and what I could use as a suitable substitute.
    Thanks in Advance
    bobw
    bobw
    US Member - 1 Year
    Topics: 41
    #208066
    I’ve just substituted rubber fuel hose of the same diameter.
    1956 Johnson RD-18
    "Every 20 minute job is only a broken bolt away from a 3-day project."
    Avatar
    rudefan29070
    US Member - 1 Year
    Topics: 12
    #208067
    Thanks Bob,
    That was my first thought but I wasn’t sure if this hose needed to be something special due to the heat being right on the block.
    bobw
    bobw
    US Member - 1 Year
    Topics: 41
    #208068
    Well, I haven’t had one blow up yet! Not much different than the other fuel hoses under the motor cowl.
    1956 Johnson RD-18
    Canada Member - 2 Years
    Topics: 432
    #208079
    You should be able to find a short length of correct size Tygon at a local small engine repair shop.
    Avatar
    2fast4me
    US Member - 1 Year
    Topics: 19
    #208082
    Ii also like the Tygon. It’s clear so you can see things happen. I save leftovers and use them for fuel lines it’s tough stuff.
    2Fast4Me
    Avatar
    drifter
    US Member - 1 Year
    Topics: 97
    #208246
    Tygon is available at local Home Depot.
    Avatar
    rudefan29070
    US Member - 1 Year
    Topics: 12
    #208292
    Thanks for the suggestion, this is the first I’ve heard of this Tygon. I will get some of this
