Home Forum Ask A Member evinrude elto mod 4357
  • #231159
    JEFFREY PLITT
      thank you . i’m missing one of the little round insulators . i can fabricate . any ideas ?
      #231161
        if you have access to a lathe, you can make them out of Acetal (Delrin).
        #231162
        JEFFREY PLITT
          thank you to all
          #231237
          JEFFREY PLITT
            OK . HAD THE LITTLE BUGGER RUNNING LAST NIGHT . SOMEONE HAD GOTTEN INTO THE POINTS AND MIXED UP THE ORDER . THAT 2ND WIRE WAS FOR THE ORGINAL CONDENSER . I HAVE A JIMMY REPLACEMENT . IS A ORGINAL TYPE AVAILABLE ? LOOKS LIKE ITS A HORIZONTAL MOUNT RATHER THE VERTICAL .
            #231290
            DAN UMBARGER
              Not sure whats available but I used what looked like the old OMC sterndrive condenser…the condenser had a bracket that surrounded the condenser. I had to drill the mounting hole bigger and solder it to the points. It worked fine but after finding the original problem I soldered the original condenser back in and it still had spark. In some older posts ( and in the Outboarder) there is a way to make one…might be something to check into.
