Home Forum Ask A Member Evinrude Lightwin 3012 Gear Case teardown
  • #7244
      I’m having troubles getting the prop shaft cap / cartridge removed from
      the gear case. I removed the two screws of course, but there’s really
      no edge on the cap to tap on. I tried a putty knife with a sharp edge,
      but really don’t want to "gouge" up the cap. Also tried heating the gasket
      edge with a bottle torch to loosen the old sealer. Lastly, I put the
      prop shaft in the vice, thinking maybe I could tap on the gear case
      with a block of wood and hammer, but there’s really no way to
      do that without putting a side force on the prop shaft.
      I don’t see where there could be a hidden bolt anywhere.
      Don’t want to break something, so …..
      "What’s the secret?"
      Thanks!
      Photo of same unit, but not mine!
        First, look for match marks so you get it back in the same position. Then, and this is according to the service manual, pull put with the prop shaft. What you started to do should work. You could always rig up a slide hammer tool, but that shouldn’t be necessary.
        #59058
          Thanks Frank! I had to plant petunias for my 90 year old mother,
          but now I’m ready to take another look at the Lightwin.
          I did notice what looked like an arrow stamped in the
          gearcase, but I didn’t notice a matching mark on the
          cap. Will look again!
          chinewalker
            With the propshaft in a vice, I lay the gear case horizontally with the driveshaft against my hip to counteract any force I may be putting on the propshaft as I tap the housing with a rubber mallet. Go gently – they’re not terribly stout.
            #59068
              I used Frank’s idea of a slide-hammer. Worked Great.
              Had to braze two nuts together to connect the
              prop shaft to the slide hammer.
              Three little bumps with the slide hammer and it was apart.
              Now, the next problem……. 😮
              After the cartridge came out of the gear case, I looked
              in and didn’t see the pinion gear. I thought that it must
              have flung out on the bench or floor. Looked for 5 minutes,
              then discovered that it was hiding and lodged in behind
              the so called "thrust bearing". I got it un-lodged by
              probing at it thru the "fill hole".
              I tried to get the pinion gear out for inspection, but
              there’s not enough clearance for it to slide pass the
              thrust bearing.
              What holds the thrust bearing in place? I tried moving it
              with a screwdriver and a needle nose, and it doesn’t
              even wiggle.
              The thrust bearing is part #15.
              P.S.- With the excitement of wanting to try out the slide hammer,
              I forgot to mark the cap for orientation. 😳
              As I mentioned before, there is an arrow on the gear case,
              but I see no mark on the cap. I can’t for the life of me,
              see any difference regarding which way the cartridge goes
              back in. My PDF manual says nothing on the subject. Thoughts?
              Thanks again!
                That thrust bearing is a slip fit and only held by an oil film. Sometimes it can be dislodged with a long nozzle air gun, or by holding the gear case with the opening pointing down and tapping the keg on the edge of the workbench. . . 😀
                #59077
                  I honestly don’t remember the reason for the match marks
                  upload img
                  #59080
                    Garry, that must be one tough oil film! I’ll try the compressed
                    air method tomorrow. Thanks!
                    Frank, maybe I’ll have to remove paint and look for
                    that mark on the cartridge cap. If not found, guess
                    I better get the micrometer out and look for the
                    reason for the marks in the first place!
                    Thanks for the picture!
                    fisherman6
                      I could be totally wrong, but I’d guess the match marks are there so when it assembled prior to machining, it will have an indicator of which way it was assembled when it was line bored / reamed. That way, when it gets disassembled and serviced, it can go back together the correct way. If it was assembled 180 degrees off it would cause a bind / premature wear if it wasn’t machined perfectly on center, which it wasn’t.
                      -Ben
                      OldJohnnyRude on YouTube
                      #59082
                      ed-sam
                        I have used a coat hanger with a sharp bend on the end to pull the bearing. Just hook the thrust bearing and pull it out. On reinsertion I use a long screw drive in the center hole and walk the bearing into place.
                        Ed
