Home Forum Ask A Member Evinrude Lightwin, serial # 4022622
  • #291083
    Peter Goodwin
      Hello all, acquired an Evinrude Lightwin serial # 4022622. I am attempting to determine the year of the motor as well as a source for parts.
      #291084
        mdl# ????
        #291085
        Tom
          That’s an Evinrude model 402, 1931 I believe.  (For seven digit numbers in that era, the first three are the model number.  For eight digit numbers, the first four are the model number.)
          This is a pretty common motor.  Likely you’ll need to find a donor motor for parts, but some things like magneto parts are used on other models.
          What parts do you need?  What is the condition of the motor?
          T
          #291087
            I believe Tom is correct and your motor looks like this.  Tubs
            #291105
            Peter Goodwin
              Thanks Guys, Yes the motor looks exactly like that.
              #291106
              Peter Goodwin
                The overall condition of the motor is good for its age. Not sure yet what parts might be needed.
                Thanks for your responses.Peter
