Home › Forum › Ask A Member › Evinrude Model
  • #11025
    auqadart60
      Have a line on a horizontal shaft Evinrude motor, but can not find anything about it. Supposedly it is a 7 1/2 hp., did run but one old plug is broken now. Any help and a link to some on line information would be appreciated. Thank you. Dana
      bill-loveland
        IIRC, they were used for portable fire pumps and inboards.
        #82096
          Model DD built from 1916 through 1927 . . . 😎
          #82097
          kees
            International Member
            quote bill_loveland:
            yes , they are !
            and…….4,5 hp
            see if you can find a model nr. close where it is bolted on the frame
            DD , DDV or DDV
            #82195
            auqadart60
              Thank you, starting to find out some information now, did not know where to start before. I know the most common answer to this question, but having a line on this motor what would be a reasonable price to offer, did run, has reverse capability, does need some work now. thank you. Dana
