Home › Forum › Ask A Member › Evinrude N?
  • #38166
    kees
      International Member
      quote viking66:
      The Tank is definitely light as far as weight goes. It could be Aluminum, I will take a magnet to it and see.
      use a sharp knife or so to see the color of the metal
      my guess it is copper
      a magnet will not help in this case
      #38167
      kees
        quote Hotrod:
        I now believe that your original tank was aluminum.
        My 1923 and 1924 N 4225 motors both have brass tanks and both have the sn plate on the brass tank, with no rivet holes in the reverse housing where a sn plate could have been attached. My1924 N 6414 motor has the aluminum tank with the sn tag riveted onto the front of the reverse housing.
        Since your N 5166 has the rivet holes in the front edge of your remaining portion of the reverse housing, indicating an aluminum tank, it appears that the brass tanks ended somewhere between N 4225 and N 5166.
        good info "Hotrod"
        I thought that the copper tank always belongs to the NS model with
        the salt water / brass lower unit
        thanks for sharing
        #38218
        viking66
          I scraped a small spot, the Tank is Copper.
          I also found a Tag from The Ohio Conservation Place dated 1942. You can see it above the Tilt adjusting arms. It has a number on it. I would try and look the person up, but maybe the family would want the motor back….LOL
          #38224
          George Emmanuel
            The NS has a brass tank. People make copper tanks because it is easy to form, strong and easy to solder.
            George
            #38514
            viking66
              Can someone please tell me how to test the Coil on this model?
              Thanks!!!
              #38570
              hotrod
                Most opposed twins are tested by connecting the 2 leads of your meter to the 2 spark plug wires. When your analog meter is set on the 1000 ohm scale, the reading is usually somewhere between 5000-15000 ohms for a good coil winding. This doesn’t test the insulation but that seldom needs testing except visually.
                #66632
                  Do you still have this Motor? I would love to discuss purchasing. Thanks!
                  -Pete
                  #66651
                    This is all I have . . .
