Home Forum Ask A Member Evinrude OEM Paint
  • #6672
    rvdriver
      I am building a 14 foot wooden speed boat with a 1958 Evinrude 35 hp Big Twin. I want to cleanup the motor with some fresh paint. It has 3 colors….2 blues and a cream white color.
      Where do I confirm the colors and buy the "spray" paint.
      I just joined the forum and this is my first post. Thanks,
      RVdriver
      #55524
      lindy46
        I just bought paint for a 1958 Lightwin – same colors. They are: Commodore Blue, Polychromatic Blue (1955-1958) and Aqua White. There were 3 different Polychromatic Blue’s over the years so be sure to order the correct year. I got mine from Effenaco – they supply Reprotint paints. Very good paint. Here’s a link:
        http://www.effenaco.com/store/index.php
        #55525
        rvdriver
          Thanks!
          #55526
          rvdriver
            How much paint did you anticipate needing to paint the engine?
            #55559
            david-bartlett
              Welcome!
              That is a great vintage motor. One of my favorite years and color schemes.
              You can also get paint here as well. http://www.nymarine.ca/
              Keep posting and bring pictures.
              #55560
                Reprotint and Nymarine are both excellent choices. You might consider one is in Canada and the other is in US. Both are great countries too!!
                #55561
                  I use NyMarine Paint as well. Been very happy with it.
                  Cannot speak for the Effanaco, as he wont sell it to us Canadians, so have not been able to try it. Too bad, I have a 60s Gale Im painting and wanted to try his Gale Orange.
                  To do a Big Twin with spray bombs, it will somewhat depend on your experience. My first few motors I definitely used more than I would now. Mainly from having to repaint the cowl a couple times, messing up the 3 tone or 2 tone lines.
                  In general, you will need about 3 cans of self etching primer. 3 cans of dark blue, 1 can of light blue, and 1 can of white. Maybe 2 if you are doing the prop as well.
                  That is a fairly tight estimate. If you are shipping it, you may want to add to that a bit.
                  Hope this helps.
                  #55567
                  lindy46
                    quote rvdriver:
                    I bought 1 can each for my Lightwin and have plenty left over. For a Bigtwin, I’d get 2 cans of the Commodore Blue, and 1 can each of the other two.
                    #55573
                      Bigtwin is MUCH bigger than a Lightwin. 2 cans wont get 3 coats on a Big Twin. You will run out. And that sucks when that happens trust me!
                      At least 3 coats leaves the best finish. A light mist coat first, then a normal coat, finished with wet coat.
                      Especially when you have it all apart, paint each piece, assemble then final coat. If you are having paint shipped , I would say get 4 cans really to make sure you have enough and don’t run out. You will use it down the road for touch ups anyways. WHen you have to ship a single can it makes it expensive.
                      #55591
                      joecb
                        Barry at Reprotint is a club member and offers high quality paint. He has been out to Constantine for several of the past years conducting refinishing seminars… a helpful guy. http://www.reprotint.com
