Home Forum Ask A Member evinrude rbm coil test and repair
Viewing 10 posts - 11 through 20 (of 27 total)
  • #67971
    JOSEPH BRINCAT
      In retrospect, some thoughts on the subject… looking at the last photo that Tubs posted ( the bare armature) It appears that the "V" portion about which the coils are wound is integral with the left shoe, see the radius at the shoe. the right end is likely inserted into the right shoe lamination stack. That said, there is no way to install a long coil like a Johnson because of the "V". As for shorter coils, the shape of the armature core being rectangular would not accommodate any modern coil that I know of. Also interesting that both of the original coils had both primary and secondary windings, I had understood that one was primary and the other secondary, this was wrong. Thanks again for posting.
      #67982
        A or J coils are way to big. I had intended to try
        to just put a coil on one side but I couldn’t get
        the laments out of the coil I wanted to use
        without braking the coating. I have come up
        with a option#-4. I have it all together but
        I’m struggling on how to attach the spark
        plug wire. I’m pretty sure it will make a spark
        but will it be strong enough to start when
        pulling it over by hand ?
        #68008
        George Emmanuel
          I agree. But what I suggest is machining that core so you can fit another coil in. The issue with the Evinrude mag plate is the raised wall that was used to hold the tar in. I don’t think it is needed structurally.– And it prevents installation of a coil from one side of the heels to the other.
          If you look at an Evinrude Speeditwin coil,(and I’m only using this as an example) the laminate has a step on each side and the cores the coil mounts to has a step. One side is up and the other down, and the coil only has a machine screw that fastens the core to the heel. There is no interlocking of the laminates. So in theory, if a Speeditwin coil would fit in the space (yes, I know it is for twin cylinders) between the heels, and if you cut out the middle of the core, machined a step on each side to match the Speeditwin’s steps and mounted it like it is on a Speeditwin mag plate, it should produce spark.
          This thread has encouraged me to seek a bad mag plate and experiment! I’ve done 4 other mag modifications installing other style coils with great success. I put a later Speeditiwn coil in a model R Fastwin, a Johnson S/V-45 coil in a 30 cu in Caille and in a 1916 Koban, and 2 OMC coils in a Caille Master 5-Speed.
          George
          #68025
            #68041
            George Emmanuel
              It is as I said, the raised ridge that is the reservoir for the tar is the complicating factor, but wow, what a nice job you’ve done! How’s about one of those Mercury Chainsaw coils? Which coil did you use?
              George
              #68044
              david-bartlett
                Man Tubs! You do some fine work!
                #68046
                jim-moffatt
                  Any single cyl coil should work, if its small enough to fit in the flywheel and mag plate. The original coils were so big most likely because very thin gauge wire wasnt available in those early days. Any modern single coil should be "hot" enough. The coil can be placed anywhere on the laminate.
                  And its likely that grinding down the laminate to fit a modern coil would cause no problems.
                  The laminates can be cut in a staircase fashion if the heels cannot be removed. But that would require separating the layers from each other.
                  What Tubs has done using a tight fitting butt joint between the old laminates and the coil laminates should also work.
                  I have to complement Tubs on his very careful work to this point. The light at the end of the tunnel is in sight now, And its a good light!
                  #68077
                  kees
                    International Member
                    quote Tubs:
                    what a solution, WOW !
                    hats off, a great compliment for your work here
                    and that you share it with us
                    including the attached photos
                    ๐Ÿ˜€ ๐Ÿ˜€
                    #68079
                      quote kees:
                      quote Tubs:
                      ๐Ÿ˜€ ๐Ÿ˜€
                      Well Kees I haven’t gotten it to
                      work as the coil is too tall and hits the
                      top of the flywheel. The pictures show
                      what challenges I face as to getting more
                      room. Still no solution as yet.
                      The faster a magneto spins the stronger
                      the spark. If I can get this worked out I’m
                      sure it will make a spark and the motor
                      would run but will it be strong enough for
                      it to start pulling the motor over by hand.
                      The original configuration is essentially 2
                      coils. It may turn out to be a waste of time.
                      quote George Emmanuel:
                      The raised wall that holds the tar could be
                      removed for more width if you needed it.
                      My issue is the height.
                      quote Jim Moffatt:
                      very thin gauge wire wasn’t available in those early days.
                      The coil can be placed anywhere on the laminate. And its likely
                      The wire looked awful fine to me Jim and
                      there seemed to be a ton of it.
                      My attempt to file down the laments and just
                      put a coil on one side ended when I couldn’t
                      the laments out of the coil without damaging
                      the cover. I didn’t know if having the coil off
                      center would work. You have answered that
                      question for me but I was using the same coil
                      so it wouldn’t have fit anyway.
                      I did make an effort to have the laments I
                      shortened touch Jim but I don’t know if its
                      necessary. Some coils just have one lament
                      inserted into the rest. So my thinking
                      was if the centers didn’t touch the over and
                      under contact should work. What do you
                      think?
                      The wife was sneezing and coughing all
                      last week and now I got it. Hard to be
                      creative when you feel like crap.
                      #68095
                      gofastgramps
                        Tubs Could you mill a pocket in the mag plate and set the coil in it ? you would have to stager the laminates.
