Home › Forum › Ask A Member › evinrude rbm coil test and repair
Viewing 7 posts - 21 through 27 (of 27 total)
  • #68110
      quote gary:
      Tubs Could you mill a pocket in the mag plate and set the coil in it ? you would have to stager the laminates.
      Yes Gary. Thought about going a all the way through.
      Could seal the edges of the coil easy enough but the
      coil tab for the spark plug runs into the gas tank. Only
      having one RBM coil to experiment with limits what
      I can try. Now that I have cut it up my options are reduced
      even more. Also I cant modify my mag plate to the point
      that I cant return to a buzz coil if in fact I’m successful
      only to find out a substitute coil won’t produce a strong
      enough spark to start the motor.
      #68112
      Tom
        Tubs,
        Very prudent approach. I worked on one of these last year, in hopes of getting something useful under the flywheel. I even considered a small gel cell battery and converting a small coil to a buzz system. The coil would have to be stood upright because of the clearance. I gave up and the motor went to the owner with a buzz coil.
        I’m glad someone is taking this project forward. Best of luck, nice job on the documentation.
        Tom
        #68232
          Mistook interference between coil laminate
          shoes with the magnets to be a problem with
          the size of the coil. Put some aluminum foil
          on top of the coil and put the flywheel on.
          Turns out there is plenty of room. Got it
          together enough to do a little test to see if it
          is worthwhile going any farther.
          https://youtu.be/DGe29iVop2o
          #68234
          RICHARD A. WHITE
            Somehow, I knew you would find a way….
            classicomctools@gmail.com
            #68265
              #68317
                All issues resolved as far as getting it in
                there. Have spent a couple days on a
                You Tube slide show. Should have time
                to finish it shortly. Don’t know when
                the weather will let me open the door
                to do an actual run test.
                #68318
                twostroke
                  Probably sometime in May….hopefully……?
                  Jim
