Home Forum Ask A Member Evinrude Simplex Remote Control issue
  • #177086
      I thought I was going to quick hook up a motor on my newly acquired Cadillac boat
      to the remote controls. Steering went okay, but the brass trunnions that go into
      the motor mounting fingers (for a lack of a better term) are froze up, and the
      threads are fatally damaged as well.
      I removed the threaded 1/4 brass tube with trunnion nut from each cable, and
      I tried heating up the trunnions with a bottle torch, but could not get either to budge.
      Tried to hold the brass tube in the vise, sandwiched between wood, but it doesn’t
      hold well.
      Even if I could get the trunnions off, it’s a super fine thread, 40 tpi, I believe,
      and I doubt if I’ll find a die locally to clean up the threads.
      Were the brass threaded tube and trunnion ever a stand alone part that one could
      order, or did they only come with the cable assembly?
      Not sure I could make new ones or not on the lathe. I’d have to come up with
      heavy duty 1/4″ brass tube. I’ve never tried turning treads as fine as 40 tpi before,
      although, it looks like one could order such a die.
      The tubes are about 5″ long, so don’t think I could make a tube out of round stock
      with a 1/16″ hole.
      I hoped to come up with something quick so I could test the boat out this week.
      Thoughts? Thanks.
      DSCN7845
      DSCN7846
        Those trunnions were staked at the factory and are not intended to move. Unlike the newer cables with adjustable plastic wheels.
        #177091
          Oops, one came out easy, the other required some effort. but the tube is threaded
          into the end of the cable’s brass end, and I guess staked! Nothing a little locktite
          couldn’t cure if I can make new ends. Presume someone has done so??
            Just re-read your reply Frank. Oh back up the truck.
            Are you saying the actual trunnion (little barrel) is staked
            on the threaded brass rod? I thought you meant that the
            threaded rod is staked onto the end of the cable.
              Actually, both
              #177120
                I do see a little hole on one side of the trunnion. I thought it was an oil hole. 🙁
                Being the trunnions are non adjustable, I guess there’s no way to
                re-center the control levers when switching motors?
                I guess I’ll re-try hooking up the cables as is, but am still interested in
                coming up with new, adjustable trunnions.
                Thanks.
                • This reply was modified 5 years, 10 months ago by Buccaneer.
                #177127
                  Here ya go….
                  9.-Connector-Kits-Remote-Control-and-Steering
                  • This reply was modified 5 years, 10 months ago by frankr.
                  #177132
                    Thanks Frank! I just ordered one to replace the worst one, for $4.99 with shipping.
                      So I put things back together on the remote controls, and think it’s going to work okay.
                      I had to remove the spring for the tiller arm friction blocks.
                      Test fired the ugly Evinrude 15 hp in the barrel, and it seems to shift full
                      in either gear. Mowing lawn as it’s suppose to rain later today, but
                      maybe I’ll have time to test the boat in the lake tool
                      https://youtu.be/-o0dTInBq0Q
                      outbdnut2
                        Careful!….when you step up to bigger motors, you get to likin’ the performance, and find yourself seeking out bigger ones. I’m at the point where if it’s under 10 HP, it has to be something really special or different for me to be interested….unless, of course, it’s free. I now look primarily for motors from 10 HP to 40 HP.
