Home Forum Ask A Member EVINRUDE trigger coil
  • #171159
    Rick Robbins
      Is it possible to use a 4 pin trigger coil in place of a 5 pin on a 1994 Evinrude 70 hp? I could swap the connectors and re-locate the wires to the correct pins, but the 4 pin does not have the black with white stripe wire. Is there a way around that issue? What does that wire do?
      #171200
      dan-in-tn
        The white/black stripe wire is for the QuickStart sensor from the cylinder head. 1994 model engines are equipped with QuickStart and incorporate different components from earlier engines without this feature. Mixing and matching would not be a good idea.
        Dan in TN
        #171220
        fleetwin
          US Member - 2 Years
          Like Dan says, don’t attempt to make that swap, you might damage the pack also….
          What is the problem you are having and why do you suspect the sensor coils/trigger?
          This ignition system is very sensitive/delicate, can be tough to analyze the sensors with just an ohm meter….
          #171223
          Rick Robbins
            I used the factory service manual and found that I had no voltages coming out of the trigger assy, then checked the resistance of each pin to pin D as instructed only to find that they all showed open and not shorted to gnd. I then took a coil assy with the wrong pins and read the resistance of the same pins. I now had the readings that were called for in the service manual. Seems pretty convincing that it’s a bad trigger assy, unless I’m missing something.
            #171224
            Rick Robbins
              Thanks Dan for the advice! I’m going to look for the correct 5 wire plug and not use the one that’s incorrect.
              #171226
              fleetwin
                US Member - 2 Years
                Not only is this part delicate/sensitive, but it is also expensive…..Why is it that you are replacing the sensor assembly? I just don’t want you to spend time/money replacing something that might not be busted…..
                #171238
                Rick Robbins
                  Followed the service manual troubleshooting directions for no spark on any cylinder. Everything was as expected until I came to the sensor coil. At that point I had .06 v instead of the required .3 v between pin D and pins A,B and C. Then the resistance checks were: D to E=446 ohms, D to A,B,C was measuring open on any scale. Since I was not getting the results the shop manual indicated, I figured the sensor coil was defunct. Couldn’t see continuing when I had results that were not what the manual called for. I’m open to suggestions that indicate I’m missing something. Not looking to spend money chasing an incorrect diagnosis.
                  #171243
                    Maybe first try probing the wires close to the sensor to confirm it is bad and it’s not one of the wires causing the issue. One wire may be broken inside the insulation giving false readings.
                    #171246
                    Rick Robbins
                      I’ll give it a shot. I see your listed as Canadien member, are you up there? We visit my cousins in Cape Breton in the fall.
                      • This reply was modified 5 years, 1 month ago by Rick Robbins.
                      #171260
                      fleetwin
                        US Member - 2 Years
                        Admittedly don’t have a manual close by, but remember the long/sensitive process. This part is so sensitive that I’m pretty sure the manual mentions different resistance readings that might be found on a few different brand ohm meters…I believe the term “impedence” was tossed around also. Were you using a peak reading voltmeter when checking the voltage output? If so, was it set to the proper scale? I won’t be home for a week or so, perhaps Dan can review the sensor troubleshooting procedures with you. In any event, the sensor works in two modes, quikstart and run. There are several tests to check output/resistance in both modes.
                        In any event, the sensor would not be my “first bet” in a no spark situation, unless you found damaged/burned/melted leads. Did you do the key switch elimination test? Did you check the pack and coil ground connections with an ohm meter on the low scale? Those amphenol connections can be troublesome also, did you check each black plug to make sure none of the pins/sockets were bent or partially pushed out? Please don’t be offended if I ask if the emergency stop lanyard is properly attached to the control or switch on the dash….Happens to the best of us.
                        Have you checked the powerpack charge coil resistance and output? If so, did you use a peak reading voltmeter? There is a “power coil” that provides power for the quikstart/SLOW systems also, but I’m pretty sure the engine will still spark even if the power coil is bad.
                        Please know that I am not trying to question your troubleshooting methods/results, but the sensors would not be my first guess. I would surely want to eliminate all other simpler causes before replacing the sensor assy. Again, this part is very expensive, and most dealers would not offer a refund once it has been installed.
                        When was the last time this engine had spark, what has changed since then? Is the battery fully charged? Low cranking speed can cause no spark due to low charge coil/sensor output.
