Home Forum Ask A Member Evinrude VRO V-4 90 HP 1989
  • #288412
    Bob Gilchrist
      My engine is a:
      E90TLCCA
      R-1809321
      OMC,
      can someone please tell me what model of hydraulic steering unit can be used on my 1989 Sylvan SS, thank you Bob Gilchrist
      #288428
        What type of steering do you have now?  Regular push/pull teleflex cable type?  If so, why is it that you want to convert to hydraulic?  The engine is only a 90hp, I just don’t think you will gain much in terms of control/ease of steering going to hydraulic.
        In any event, I would just consult the teleflex accessory book, I’m sure the kit part numbers are spelled out clearly there.   Keep in mind that some of these units are a little bulky, along with the hydraulic hoses that are flexing around, so transom well dimensions and clearances should be considered…
