This old photo shows just the spring and nut without a washer. Not sure if that is correct though.
If the cone clutch was slipping, then I could see a washer being used to increase the friction between the cone and the prop. After cleaning them, I like to put a light coat of grease on them to help prevent them from corroding tightly together. If you hit something hard with the prop and the parts don’t release, you’ll have to take it all apart to replace the shear pin.
