Home Forum Ask A Member expecting father of a new to me 9622a
  • #1410
    crosbyman
      OK guys this is my winter 2016 project but I am anxious
      been cyl. soaking it for a good week now and the flywheel is stuck solid ..real solid forwards or backwards.
      I havent bashed (coaxed) the pistons yet. walls look good no rust in sight
      Motor is like new aside from comestic scratches.
      probably sat for years. no bugs Inside 🙂 and I don’t suspect yet.. that it went in the drink
      what scenarios am I looking at….
      motor is lot more complex than QD FD styles. funny carb is side mounted. any inspection ports on this 9622a so I can squirt/inspect the rings ??
      not a screw has been taken out of this baby. all bolts -screws covered in original paint.
      #15366
      david-bartlett
        Crosbyman,
        These are nice little motors. They have some design quirks, but nothing you can’t handle. Once you remove the carb, you get access to the port area. This is a bit different than your typical OMC twin, but nothing to lay awake worrying about.
        Good diagrams on Marineengine.com site.
        Enjoy your motor.
        #15370
        cajuncook1
          To rule out a frozen powered vs a damaged lower unit issue being the cause of a stuck motor, please remove the lower unit. If the power head turns freely after you remove the lower unit, then you have resolved your ,stuck powered issue, gained a gearcase issue.
          #15372
          crosbyman
            OK off with the gearcase …. all diagrams saved (printed)
            #15516
            crosbyman
              well the gearcase came off. powerhead still won’t rotate either way.
              motor is so clean inside I can’t believe it .
              lower housing and gearcase are spotless ….no exhaust carbon or oily deposists to be seen. impeller housing spotless 😮
              Aside from surface scratches on the cowling and darken plugs I would swear this engine laid dormant for 51 years !!!
              Not bad for $50 if I can get it to turn 🙂 IF I fix it I will need a new motor to work on next winter 😆 😆
              #15520
              dave-bernard
                I had a 3hp evinrude stuck solid. it ended up being oil dried out over many years . took a lot of soaking and time. once apart it was like new inside.
                #15521
                weedlessdrive
                  I would pour some ATF fluid in the cylinders and work it around to coat all the walls. Let it set for awhile then try to work the flywheel.
                  #15522
                  dave-bernard
                    I ended up going into the crank case to soak that is where it was stuck.
                    #15672
                      Yes,
                      Take your time & let it soak! Even if it soaks for a few months. Start another project then come back to it. Been collecting for over 30 years & soaking for months will deliver a loose motor. Small taps on the pistons but no breaking rings, PATIENTS!
                      #15673
                      1946zephyr
                        Yea, I’m believing that it’s stuck from just sitting. Motors that sit in a damp area, will collect moisture inside and lock up. I believe once you get the piston free, you will have a nice running motor. I sold one of these on a little 12′ Crestliner a few years back.
