No crankshaft seal to remove. Did you remove the 2 screws behind the manifold/reed plate? See enclosed pic. These have to come out to split the crankcase.
Edit – you also need to remove the 2 taper pins. See pic. They drive out from the back toward the front of the case.
This reply was modified 3 years, 8 months ago by bobw.
This reply was modified 3 years, 8 months ago by Mumbles.
