I was given a Neptune 15B2 and 6hp Chrysler that have both been setting since the late 70s, both were well oiled when put up compression seems good. The float is stuck to the shaft on the Neptune any suggestions how to get it lose so I can re-coat it? also need a prop and prop nut for it.
Also any suggestions on where to get parts for the Chrysler, going to rebuild the carb, fuel pump and replace impeller and probably points and condensers (eliminate all the problems before I go fishing with it.
Doug
Doug
turned off?
