@Mumbles
I’ve never used that anaerobic flange sealant, I might have to give it a look. I see you’re using a prep with it, I’ll assume it’s the same as the Loctite primer – that is, it will cause the sealer to set-up whether or not the surfaces will catalyze the reaction?
What’s the consistency of the product? Thin or thick liquid? Paste? Like RTV or?
(And that’s something I need to learn more about.. apparently, some metals / platings don’t give up enough ions to catalyze the anaerobic curing process, at least in the case of Loctite.. or so I’ve been told. Can’t attest to the truth of that, yet.)
