Home Forum Ask A Member Fix for spun hub?
  • #8219
    jim-moffatt
      I have an Elgin 12 hp prop with a spun fubber hub. I have heard of regluing it. Does anyone have any experience with repairs that work? Could a prop shop fix it?
      #64822
        The normal prop shop repair is to replace the hub. But that means they need a new hub to put in it. Unlikely that they have one.
        A last resort fix is to fabricate a solid hub and locktite it in there permanently. Of course that defeats the purpose of a cushioned hub.
        #64826
        squierka39
          I have used JB weld epoxy to glue the hub on an Evinrude 15hp. That was more than 10 years ago and it’s still holding.
          #64828
          amuller
            Does anyone know that the dimensions are supposed to be for rubber hubs? How much of an interference fit? How hard the rubber is supposed to be? Etc…
            #64838
              US Member - 2 Years
              Can pin it from either side with roll pins.
              #64842
              chinewalker
                Start with taking it to a prop shop. Worst they can say is they can’t fix it. Heading into the offseason, they may want the challenge as their business slows down.
                #64854
                eviltwin
                  I wonder if 3M 5200 would work. Or Window Urethane. The urethane is tough stuff.
                  #64904
                  reivertom
                    I saw some liquid rubber advertised on TV the other day and wondered if it could be used for spun hubs. The commercial is cheezy but It looks like it cures really tough but pliable.
                    #64911
                    Randy in Tampa
                      Hmmmm,time to experiment,great idea Tom …might work on other applications 😉
                      quote reivertom:
                      #64923
                      fisherman6
                        A somewhat different application, but I have used castable urethane to create a new hub on a prop for a motor once. It worked well and the person I sold the motor to is still using it all summer for the second year now. It was one of those oddball 5hp Johnsons with the 6hp powerhead and the 4hp exhaust leg and lower unit. It had a ribbed / splined hub so a but different, but I’m thinking of trying it for a 10hp OMC prop to see how it works. Not a super cheap solution though.
                        -Ben
                        OldJohnnyRude on YouTube
