Home Forum Ask A Member Flambeau Dystopia?
  • #198008
      I’m at the stage in the Flambeau project
      to start “putting it back together”.
      When I took apart this “stuck”, oddball engine,
      I came to the conclusion that it probably never
      ran after the last time a previous person
      worked on it, as part of the “stuck” problem
      was the cylinder “skirt end” was smashed down
      into, and cracking the piston skirt, as the
      cylinder alignment pin was “not” aligned.
      The other “stuck” problem was the top ring
      on the top cylinder was a little rusty, but
      that would have happened after it was long
      abandoned.
      Seeing how it didn’t run after the last guy worked
      on it, I have no idea if the pistons were
      assembled in the cylinders correctly, and
      the nice little diagram I made when I took
      it apart, may be worthless.
      I’ve past learned from the “Sages” here, that the
      long, slopping, “ramp” side of the piston goes
      toward the exhaust ports, and the “step” side
      goes toward the intake ports.
      This knowledge is not helping me on this Flambeau.
      No matter which way the piston is inserted, only
      a portion of the intake ports will be on the “Step”
      side of the piston.
      In the “As Found” position, the 3rd port and 1-1/2
      (of the 3) intake ports fall on the “Ramp”, or
      conventional “exhaust side” of the piston.
      If I were to install the piston “NOT” the way found
      when I took it apart, that is, to rotate it 180 degrees,
      the so-called 3rd port and 1-1/2 (of the three) intake ports fall
      on the step side.
      It would seem “more correcter” to install the piston oposite
      of the way I found it, but I’m having lack of conviction
      in doing so. If I find out I installed them wrong, and go
      to all the trouble and mess sealing the case halves together,
      it’s likely not coming back apart again, lol
      Only one of my old outboard repair books even mention
      Flambeau, and they are calling it a “Three port” engine,
      but I could glean nothing else useful from the book,
      regarding putting the engine together correctly!
      Ideally, if someone had documentation from some obscure manual,
      or photos showing the correct orientation of the pistons,
      I’d be forever grateful. If not, your knowledge and thoughts
      appreciated anyway!
      DSCN9017
      DSCN9018
      DSCN9019
      DSCN9020
        P.S.- If someone had a running Flambeau, a kind person may look in the spark plug
        hole to confirm the orientation, ie., ramp / step of piston. 🙂
        outboardnut
          Maybe Pine Tree Boating Club could help
          https://www.youtube.com/watch?v=cUT83Ot7hto
          #198034
            Davy sent me a photo of his Flambeau, and it appears that the piston “Step”
            in on the opposite side of the cylinder locating notch.
            Of course, if others want to confirm, that would be great!
            I’ve watched that video a few times before……. hope I can make my
            own video this summer on my Flambeau running!
            Piston-Orientation
            • This reply was modified 4 years, 10 months ago by Buccaneer.
            #198043
            fifty20ne
              Maybe this guy can help?
              https://appleton.craigslist.org/bpo/d/oshkosh-flambeau-outboard-motor/7084932428.html
              00U0U_2wfmKsPVWxg_600x450
              Cut-away display motor from 2005 & 2010 Tomahawk meet!
              Picture in AO mag also?
              Tomahawk20052088-XL
              tomahawk-201020210-XL
              tomahawk-201020211-XL
              • This reply was modified 4 years, 10 months ago by fifty20ne.
              #198057
              fifty20ne
                Article from Oct 2015 by “Wayne Schoepke” !!!! A++++
                F2
                F3
                F4
                F1
                #198076
                labrador-guy
                  Pine tree guy “dockbuster” running a Flambeau! I knew there was a Mercury connection!
                  Is there lead in a lead pencil?
                  #198077
                    Fifty21, Wow, thanks for the info!
                    From the cut-a-way, it would appear that the piston step is
                    on the starboard side. Assuming that the cut up Flambeau
                    was correct, that would be a great help, especially if
                    it match up what I believe from Davy’s photo.
                    I’ll have to take all my tips to the garage tomorrow and
                    see if I can reach a happy conclusion.
                    I’ve looked in the archives previously, and found two articles, but did not see
                    Wayne’s info, which looks to be very helpful!
                    Much appreciated!
                    dave-bernard
                      I have never seen one but could the cyl be upside down. just asking.
                      #198094
                      fifty20ne
                        Hi Bucc,
                        Glad I was able to help!
                        I don’t own a Flambeau
                        But I did remember the
                        Cut-away display! In AO
                        And Neds Tomahawk site.
                        I enjoy all your projects
                        With all the great clear
                        Pictures!
                        I believe the cut-way
                        Motor may belong to
                        Peter Hunn per Wayne.
                        Not sure if it was done at
                        Factory or someone
                        Duplicated factory display?
