Home › Forum › Ask A Member › Flambeau Rewind Won’t Engage
- This topic has 5 replies, 4 voices, and was last updated 4 years ago by Buccaneer.
March 28, 2020 at 2:32 pm #198676
There’s not enough drag on the dog plate to cause it to ride up the ramps
to engage the flywheel. Can’t find any diagrams on the rewind or magneto.
There was a small spring under the big nut when I took it apart. Didn’t
look like it belonged. Tried other springs, rubber grommet, etc. to induce drag,
to no avail. If a too long or spring with too much tension is used, it raise
the dog plate up the ramps, without pulling on the rewind rope.
Photos and a couple of short videos to show how it works.
Ideas welcomed, and parts diagrams or photos of the guts of an actual
working rewind would be cherished!
Thanks.https://youtu.be/M3cuepJYpdA
https://youtu.be/mN-C7ifKEYoPrepare to be boarded!
March 28, 2020 at 3:10 pm #198683in the video it looks like the sheave is not pivoting in the center.
March 28, 2020 at 7:40 pm #198717I think I have it fixed now.
I noticed the bolt had been re-peened and had non-factory looking punch marks.
I wasn’t sure if the plate was loose on the pin, or if someone had it apart before.
I had to grind the end of the pin off to get it out of the plate. Once apart, I discovered
there’s a copper clutch band that provides the needed friction on the dog plate.
I made a new pin and the old one was too short to re-peen once I got it out.
Then bent the clutch band tighter and reinstalled everything. I tested it out
on the motor, and it seems okay so far.
Took the rewind back off as I need to peed the pin tomorrow, and paint the rewind.
I’ve never seen this type of rewind before.Prepare to be boarded!
March 28, 2020 at 8:18 pm #198723Nice detective work and fix.
"Every time you remove a broken or seized bolt an angel gets his wings."March 30, 2020 at 11:32 am #198802Great work Tom! My Flambeau recoil works fine, so I didn’t mess with it. Thanks for taking one for the team!
Makes me wonder what would happen if Flambeau and Bendix had teamed up to make an outboard?
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
March 30, 2020 at 11:44 am #198809I’m holding off bolting the rewind on until I’ve test ran it in the barrel,
as if I have to reset the high and low speed needles, it’s got to come
off anyway. If this nice weather holds out, I may be testing some of
this winter’s projects out soon! Was 50 degrees yesterday!Prepare to be boarded!
