did you perform a resistance test between the plug boots and frame ground to confirm all is ok each coil should read between 4-8 kohms approx. depending on manufaturer
did you adjust timing per this video
http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
condensers are tricky and may…. be bad even new ones . you can do a “basic” test for shorts or open but the real leak test is done with high voltage (250vdc +) if you have testing eqpt.
the western region AOMCI has excellent articles by m.Mohat
see articles 1-4 on condensers … how to test and fixes
