Home › Forum › Ask A Member › Flywheel "Puller" plater discovery
- This topic has 17 replies, 12 voices, and was last updated 11 years, 5 months ago by
cajuncook1.
April 26, 2015 at 10:49 pm #14820
Well something good came out of my post on flywheel pullers. I was ready to buy a strap wrench but now I will make the cheap flywheel holder.
April 26, 2015 at 11:41 pm #14824You can also make a strong and cheap strap wrench out of an old deep-well socket and a length of salvaged car seat-belt material. Cut the belt to an appropriate length, and sew or (better) super-glue & sew the ends together to form a loop.
With a grinder, cut a slot down the side of the socket, just wide enough to slide the glued / sewn end of the seat belt into it, the long way. Then loop the belt around the flywheel, wind the socket ’till it’s tight, and put in a socket wrench to hold it.
Absolutely unbreakable, and with a very wide grip. If the belt material slips, just put a little rosin dust on it.. and it won’t.
Here, this is the basic idea.. you can make them many different ways, out of whatever you have around. Great use for a cracked deep-well socket, cut your slot right through the cracked area.
April 27, 2015 at 12:18 am #14831I have used a strap wrench working electrical tightening P.V.C. coated G.R.C. pipe in water treatment plants before ever using on outboards. For me it works well on outboards. We had this exfootball electrician that would break them on a regular bases. š®
April 27, 2015 at 1:56 pm #14850I cut the strap off my cheap strap wrench (Princess Auto) and replaced it with a piece of old serpentine belt from my truck. Crazee glued the end together and it doesn’t slip or stretch a bit!
April 27, 2015 at 2:11 pm #14851I have found that using the rope sheave as a puller is not the best idea. But if you snug the nut up against it to put a little upward force on the flywheel, then knock the nut with hammer, the AT, LT, DT and similar Johnson flywheels usually pop off. If that doesn’t work immediately, I go the traditional route with a puller.
Tom
April 27, 2015 at 2:54 pm #14857I’ve had a few 1930s Johnsons with the center knocked out of the rope sheave due to too much force being used on it as a puller. Best to use a regular puller and save the rope sheave…
April 27, 2015 at 3:00 pm #14858quote Chinewalker:I’ve had a few 1930s Johnsons with the center knocked out of the rope sheave due to too much force being used on it as a puller. Best to use a regular puller and save the rope sheave…Agreed!
But watch the threads on the early Johnsons as they were not standard quarter inch threads but #14 or something with a different pitch.
April 27, 2015 at 7:51 pm #14874Jim Moffatt, what a nice home made tool. Thank you for sharing!!!
