Home Forum Ask A Member Fuel mixture
  • #210368
    Ron Copeland
      1922 J 25 2.5 Johnson what oil should I use in the fuel and what ratio thanks Ron
      #210383
        Old-Johnson-Oil-Ratios
        joecb
          >>>> oil is cheap , parts are expensive <<<<
          #210435
          Ron Copeland
            Thanks very helpful regards Ron
            #210449
            Ralph Simmons
              oil that’s is in above chart SAE # 40 and # 50
              where do you find it ?
              tractor supply store ? Napa ? etc.
              thank you ralph
              #210471
                The chart refers to the automotive motor oil they used “back in the day”.
                Substitute your favorite TCW rated outboard oil, using the same mix ratio.
                • This reply was modified 4 years, 5 months ago by Buccaneer.
