Home Forum Ask A Member Fuel oil ratio
  • #177287
    yooperrigged
      I am getting differing opinions….1960 Evinrude 5.5 Fisherman. Should I use 16:1 or 24 :1? This is a recent purchase so I have not run it yet. Thanks in advance all.
      #177293
      bayham3261
        a good quality outboard oil at 24:1 should be fine. no harm with going a little richer… just more smoke.
        A little information is a dangerous thing!
        #177295
        Randy in Tampa
          Amsoil full synthetic 24:1 Walmart tcw3 16:1 depends on oil🤔
          Rotary valve Johnson’s Rule!
          #177298
            Your 1960 Fisherman still has sleeve type bearings on the rods and called for a 16:1 mix. The ’61 motors were the first year motors with needle bearings on the rods and also the first year for 24:1 mix being used with these motors. That lasted until ’64 when 50:1 became the norm.
            #177314
            bayham3261
              Yes i believe the original specs (for that generation of plain bearing engines) was 16:1 (1/2 pint per gal.) mobileoil outboard or SAE 30 mix… not sure the quality of the original stuff. This was before my time. I’ve always understood that modern TCw3 is better stuff so mixes can be a little leaner. I have ’57 Viking 5hp that ran for years and years on 24:1 TCw3. In any event you can’t go wrong with a heaver mix.
              #177319
              kerry
                Like Mumbles said, yours is a plain sleeve type bearing motor, Clearances weren’t very tight, since machining techniques were not as close as modern days. Those clearances is why your motor needs QUANTITY, not quality of oil. The oil film is what keeps bad things from happening between the bearings and crank, rods, pins, etc. As many would say, oil is cheaper than parts.
                #177341
                yooperrigged
                  Ok since I use Amsoil anyway I’m going with 16:1. It will keep the mosquitoes away.
                  #177343
                  Randy in Tampa
                    Too much oil never killed a motor, and the Amsoil full synthetic doesn’t smoke that bad 🤫
                    #177357
                      #177358
                        • This reply was modified 5 years, 10 months ago by Tubs.
                        • This reply was modified 4 years, 2 months ago by Tubs.
