Home Forum Ask A Member Fuel oil ratio
  • #177493
    bayham3261
      Thanks Tubs… interesting stuff. I’ve never seen that updated Johnson oil table before. Good also to think about the public view/opinion of smokey engines.
      A little information is a dangerous thing!
      #177537
        https://www.enginads.com/otto/
        • This reply was modified 5 years, 10 months ago by Tubs.
        #177562
        PugetSoundBoater
          This correct oil ratio topic comes up now and then. Makes me think of a comment an Unlimited Hydroplane crew chief said to me once in a conversation.
          “Oil is your friend” Kinda referring to the comment by Kerry a couple days ago.
          Robbie Robertson
          #177586
          fleetwin
            While Tubs is certainly correct, oil quality has improved greatly over the years, I’ll stick with the theory he mentioned when it comes to plain crank/rod bushing engines, at least on any of my nicer engines that don’t get that much use. While the environmental factor is one that I selfishly have not considered, it is amazing how little these engines smoke at 16:1 when properly tuned…And, the 1960 models have a thermostat which will heat the engine up a bit more, reducing smoke even more.
            #177595
              Kerry hit the nail on the head. I have a shed full of blown 5.5hp and 7.5hp powerheads from past owners that had no business running them. These NEED the volume of oil to seal properly.
              Or run them at 50:1 and blow them. They can make more right?
              #177638
                https://youtu.be/5GRrmslnz2A
