Home › Forum › Ask A Member › fuel tank cleaning
- This topic has 16 replies, 10 voices, and was last updated 8 years, 10 months ago by
davesko.
March 25, 2017 at 4:49 am #6607
What is an effective way to clean a fuel tank? Just bought a seaking 3hp with built in tank and it had 40 year old gas in it along with sludge and varnish.
Thanks GuysMarch 25, 2017 at 11:15 am #54853A handful of nuts and ammonia. Not peanuts. Let it sit for a few days shaking it every so often.
March 25, 2017 at 12:05 pm #54856Use the method that elgin2 suggests but, in case ammonia doesn’t work, try apple cider vinegar (preferably the unpasteurized kind if you can get it — direct from an orchard is typically the only place to get it). I have had better success with apple cider vinegar than ammonia, although ammonia seems to work too.
Make sure to rotate the tank when letting it sit. While the vast majority of the sludge will be on the bottom, the sides (and even the top) will have some sort of residue as well. I never have figured out a good way to seal the top of a gas tank once the gaskets and parts are removed. Anyone have any suggestions?
March 25, 2017 at 1:44 pm #54862don’t forget to decrud the two vent small holes in the gas cap. I had to look :geek: closely a few times to find them
they are easy to miss … just rotate the small metallic plate to line up with the holes and push out the crud with a unbent paper clip till you see the light shine.
March 25, 2017 at 8:45 pm #54878Anonymous
I can’t take the smell of ammonia so I’ve used E85 gas.
Steve A W
March 25, 2017 at 9:20 pm #54880Edit: Oops, nevermind, wrong kind of tank.
March 25, 2017 at 9:33 pm #54882March 28, 2017 at 8:04 pm #55125Thanks guys used ammonia 1st then apple cider vinegar and rinsed with methanol, now its spotless
March 30, 2017 at 11:59 pm #55226I didn’t know about ammonia.
So it disolve the varnish from old fuel ?
Great to know !
Is there any side effect on steel, aluminium or brass ?
I think it cleans brass, Autosol smells the same thing.March 31, 2017 at 2:05 am #55233Dissolved all varnish and the apple cider vinegar got rid of the corrosion. Methanol dried it nicely. Of course I had nuts in with the ammonia and vinegar shaking it often. Total time 4 days. No side effects , just a clean tank.
