Home Forum Ask A Member Gamefisher 7.5
  • #265618
    Gary Pasquale
      Can anyone please help me identify the year and model of my 7.5 hp gamefisher? I can read the first 3 numbers of the model number “217”, and all of the serial numbers 08-194470. I need the year and model so I can find ports for it.
      #265622
        Need the rest of the model number.  217. what?
        https://www.discount-marine-parts.com/ob_eska_sears.html
        #265623
        Gary Pasquale
          only the first 3 numbers are readable
          #265634
            I’m not sure what year they switched over to “Solid State” ignition from “Points and Condenser”, but
            that may help narrow it down if you know what your has.
            Gary Pasquale
              Electronic Ignition.
              #265658
              seakaye12
                Gary,
                Here’s a guy on ebay that is selling a variety of Gamefisher Owners Manuals.  Have a look at the covers and see if you can match yours up.  Then….after you get a idea of the likely year….go to the discount marine parts site that frankr linked to above….and pick a model number.  Then….see if the parts for that model seem to match up with what you have.
                Not 100% definitive….but it’s a starting point.
                https://www.ebay.com/sch/m.html?item=264697987470&_ssn=blauhett&_osacat=0&_odkw=&_from=R40&_trksid=p2046732.m570.l1313&_nkw=gamefisher+7.5&_sacat=0
                #265659
                Gary Pasquale
                  TY, but unfortunately i didn’t see anything that matched my cover.
                  #265667
                    Here’s a photo and parts for sale of a 1979 model.
                    https://thebrazilianconnection.com/79sears7.5southparts.html
                    seakaye12
                      Gary,
                      There is a Gamefisher Model Number but then there is also an engine model number.  That model number should be visible on the powerhead.  The carburetor may also have a tag attached.  These numbers might help you pin down the year.
                      Depending on exactly what parts you need….the engine model number may be all you need.
                      There are some very good Tecumseh Service manuals available as PDF.  Let me know if you need a copy.
                      #265706
                      Gary Pasquale
                        TY TY TY now I can’t wait to get home and look for those numbers. I will be in touch, and thank you again.
