Home Forum Ask A Member gas oil ratio for a 1968 Johnson 15hp electric start
  • #237694
    Jim Potts
      Hello,
      I just purchased a 1968 Johnson 15hp electric start outboard motor. I have a couple of questions:
      1. what is the oil to gas mixture ratio?
      2. does anyone have the starting procedures for this electric start motor. I bought it without starting it because it was just a throw-in with the boat and trailer.
      thank you!
      Jim
      #237695
      crosbyman
        Canada Member - 2 Years
        50/1 usually in those years
        before you start it
        check or better yet replace the impeller …. change gearcase oil and check for water intrusion if you have water you will need to reseal the GC … use new nylon washers when closing it up
        pump it up with fresh gas and try it out … check water pump operation you may need a carb job (not complicated) if rough
        post mdl #…. I found no 1968 15hp Johnson listed
        • This reply was modified 3 years, 9 months ago by crosbyman.
        #237701
        Jim Potts
          Thank you! I’ll check to make sure I have the year right.
          #237703
          crosbyman
            see listing for 15hps
            #237717
            Jim Potts
              yes, you are correct. It’s a 1956 Johnson 15hp electric start. So it must be the E-10. Besides the helpful info you shared on what to do before trying to start the motor. What about the actual steps for starting it? Choking, throttle, push button, etc. All the outboard motors I’ve started in the past have been manual pulls.
              thanks again.
              #237718
              Jim Potts
                Apologies to everyone, the correct year of my motor is 1956.
                #237719
                Jim Potts
                  and with a 1956 year motor; still 50:1 gas to oil mix, right?
                  #237720
                  bobw
                    Nope. If it’s a 1956 model, correct mix is 16:1. Some will tell you that you can get by with 20:1 or 24:1 but I think it best to stay with original factory recommendations.
                    β€œEvery 20 minute job is only a broken bolt away from a 3-day project.”
                    • This reply was modified 3 years, 9 months ago by bobw.
                    #237724
                    crosbyman
                      if you have a pressure tank system … keep the lid shut so pressure can build up in the tank to feed fuel up to the engine…
                      fill the carb by pumping the tank button 5-10 times
                      typical you have a electric choke push button for the electric choke so just push it while starting the engine release it when started throttle in neutral always
                      btw great engines…pamper it oil it as per specs !!
                      #237733
                      JOHN HOLBIK
                        Johnson made a 15hp around 1968 it was called a Percheron I know this for a fact as one of our customers at our resort brought one and I guided him for the week.The motor ran well and trolled great I believe it was a one year offering I also saw it in an advertising brochour back in the day.It had a hood on it that looked just like the Gale 15 from the early 60s.Maybe it was only avalible in Canada they called it a work horse model.
                        We ran all our outboards from 1952 to 1964 on 25 to one and the later ones on 50 to one all of our motors had thousands of hours on them I have a 56 Johnson 15 hp it is my favorite engine it has a gazzlion hours on it and it runs perfect..
                        Our mix system was simple one 5 gallon milemaster tank one quart oil for old motors.
                        1 5 gallon milemaster tank for newer 1 pint oil we never went with the later omc 100 to one.
