Home Forum Ask A Member Gear case pressure testing
  • #163239
    Tinman
      How do you go about pressure testing a gear case? I hear a lot of talk about it and would like to learn how. How many psi are required and are there tools that can be purchased to do this or are most of the testers home made? Thanks!!
      #163379
      fisherman6
        Tinman, there are commercially available pressure testers and many use them. Stevens instrument makes an excellent pressure tester as well as a vacuum tester. Some have adapted radiator pressure testers to work with gearcases with good results. Some of us use home made testers. Mine is a tester I made myself in my shop. It uses a 0-15psi gauge, a Schrader valve, and a machined aluminum body that screws into and seals against the drain plug hole. Testing is normally done between 6 and 10psi. Below is a link to a video I recently made in a series showing the tune up of a 1959 Evinrude Fastwin. I hope this helps.
        -Ben
        https://youtu.be/-DPsE__7J4Q
        OldJohnnyRude on YouTube
        #163398
        Tinman
          thanks i appreciate the help! may try and make one myself. going to watch the video now. I have found no easy way to remove the seals, so why do it if you dont have to!
          #163429
            gee.. optical illusion…. the front of that gearcase looks badly cracked ???
            #163687
            fisherman6
              I think what looks like a crack in the front of the gearcase in the video is just sealer that squeezed out and tyat atring of sealer got dragged down from the seam of the case. I assure you there are no cracks in this one.
              -Ben
              #163688
              fisherman6
                Old seals can be problematic to remove. They seem to get easier after you pull a few dozen and get the hang of getting them out. Still, there are stubborn ones that present a challenge. Ben Dittmar recently made a few videos showing how he gets seals out of the OMC gearcases. He does it very much the same way I do.
                -Ben
                https://youtu.be/L3fqRsx8VQM
                https://youtu.be/toGT5UlUB5U
                https://youtu.be/pKLb5IW3x0U
                • This reply was modified 7 years, 2 months ago by fisherman6.
                #163704
                Tinman
                  Good videos. I’ll try that approach! Hopefully I don’t break anything! Lol.
                  #163718
                    Tinman
                    I agree with you for the most part…..If there is no water present during routine gear lube changes, don’t go looking for trouble…. And yes, removing some of the seals/shift rod orings can be difficult, you run the risk of damaging castings by prying with inappropriate tools or using too much force.
                    A pressure tester can surely be “home made”, but again, it is easy to get fooled by testers that have their own leakage problems….In other words, you may go looking for “gearcase leaks” that are really just faulty/leaky testers.
                    It is always a great idea to submerge the gearcase in water during a pressure test so you can see exactly where the leak is coming from. Never just disassemble a leaky gearcase before trying to pinpoint the actual leak(s) using a pressure tester.
                    Generally speaking, vacuum tests are usually only done on later style gearcases with “back to back” lip seals.
                    What type of engine/gearcase are you concerned about? The old style OMC two piece “clam shell” gearcases are relatively easy to work on, but not all that easy to seal up properly.
                    So again, I agree with you, don’t go looking for problems if your gear lube appears to be free of water. The best idea is to check/change gear lube frequently to catch little leaks before they become major and damage/destroy your gearcase.
                    #163729
                      In the book CHEAP OUTBOARDS.. the author suggest that changing oil during the season is probably the best thing to do unless one wishes to go all the way with a reseal.
                      I have done a few and it is not that hard but really….a lot of boaters will use their boats 50-75 hours per season so changing the oil in the old kicker won’t cost much with Wally mart oils and takes 15 minutes.
                      you can buy a fair quantity of bulk 90w oil for the price of the drive shaft and prop seals ….
                      Of course if the leak is very serious go for it …… lots of utubes to teach you
                      https://www.youtube.com/watch?v=GCkpGD4bgDI
                      if you live in snow country… make certain to drain and refill before the cold temps come in
                      #163730
                        If you don’t have all the necessary tools, there’s an alternative way to check for leaky seals. All you need is a spritzer bottle with some soapy water in it and an air supply. It doesn’t matter if it’s regulated from your compressor or from a few pumps with a bicycle pump, as long as it can deliver at least five PSI, which is probably more than the gearcase can develop while it’s in operation. Too much air pressure might flip an old seals lip inside out making an unnecessary teardown mandatory.
                        All you have to do is drain the oil thoroughly and reinstall the drain/fill plugs securely before spraying the soapy solution on the driveshaft, prop shaft, and shift rod seals along with anywhere else oil could leak out. Any leaks will show as bubbles or foam around the leaky area.
                        Leaky-Drive-Shaft-Seal
