Home Forum Ask A Member Gear case pressure testing
  • #163744
    Tinman
      thanks everyone for the good ideas. Pressurizing the gearcase and using bubbles is a great idea. Should of thought of that one myself. I am a hvac tech and regularly use soap bubbles to test for gas and refrigerant leaks. Is the thread size on the drain and fill plug a standard size? Thanks for all the help!
      Bryan
      #163745
      Tinman
        Most of my motors are 1950’s johnsons and evinrudes. And we finally got some snow here in central missouri!!! Almost forgot what it looked like since we did not get any last year.
        #163780
          Yup, standard 3/8 – 16 UNC.
          #163781
            And we finally got some snow here in central Missouri!!!
            Snow? What’s that?
            Every year around the middle of January, I notice the days are getting longer and the daffs are starting to poke their heads out. I even got to mow a little bit of lawn yesterday!
            #163784
              Here’s the proof! ☺
              Daffs-Jan-14-2019-
              Mowing-Jan-14-2019-
              #163792
              crosbyman
                taking about HVAC…. I saw a car AC repair kit the other day which comes with a can R134 freon and a special can to help “reseal” a leaky car AC system .
                these 2 pressurize cans come with a cable/hose with a control valve and built in pressure meter
                buy simply changing the AC car side connector end to standard 3/8 – 16 UNC any chance these C kit could become an easy to use LU test kit.
                a) to check leaks with a bit… of r134 gas
                b) to use the sealing agent can to actually swell up the LU seal joints if any leaks are detected
                replacing the end connector to a standard 3/8 – 16 UNC. would make for an easy to use test & reseal kit .
                https://www.walmart.com/ip/R134A-AC-Car-Air-Conditioning-Refrigerant-Recharge-air-conditioner-Measuring-Kit-Hose-Gauge/227748040
                https://www.walmart.com/ip/EZ-Chill-Auto-A-C-Recharge-with-Leak-Sealer-Refrigerant-R-134a-11-oz/111930024
                r134 is apparently not to bad for the ozone layer and not much would be used anyway … compared to millions of leaky car AC
                #163796
                Tinman
                  That would probably work just fine!
                  #163848
                    • This reply was modified 4 years, 2 months ago by Tubs.
                    #163850
                    Tinman
                      Probably be making my own soon!
