Home Forum Ask A Member Gearcase flushing procedure prior to Lubriplate 105
  • #183152
    seahuntboater
      Greetings. Not taking apart an elgin gearcase but want to flush out old gear oil and replace with Lubriplate 105. Thinking of using gasolline, kerosene, spinning shaft with a drill and doing it a couple of times then blowing air through fill/drain holes prior to greasing. Any advice appreciated. Thanks Ralph
      #183155
        I’d opt for the kerosene or mineral spirits over gasoline for safety reasons.
        #183172
        westwind
          Canada Member - 1 Year (includes $3 online payment fee)
          You can also warm it up with a heat gun so it runs out more like oil. It should have thin grease in it. I wouldn’t use gas…..
          #183187
            US Member - 2 Years
            Once you get it clean run some 30wt oil thru it & then redrain, then refill with 105. I use a horse syringe from the feed & tack store. It has a tapered end that fits into the gearcase fill port. If you ever want to change the 105 gently heat the case & it will melt too. The 30wt gets most of the thinning from the solvent removed.
            #183199
            seahuntboater
              Thanks to all. got the lubriplate coming from amazon. $10.45. cheaper than Napa and they bring it to my door.
