Home › Forum › Ask A Member › Gearcase pressure tester
Viewing 11 post (of 11 total)
  • #84204
      I made my radiator tester work for a gear case tester. The pressure part works fine. The down fall compared to the Stevens is that they give you a bleed off valve; whereas with the radiator tester, it just bleeds off as you unscrew the fitting from the gear case. No biggie, just a little crude.
