1960 Johnson Super Sea Horse 40hp.
Upon cleaning up the gears in the gear case, the reverse gear brass bushing was
loose and just slid out – – – the forward gear bushing was stuck and had to be "coaxed" out with a hammer.
Should it be forced back in ? or, should it fit loose and spin freely like the reverse gear.
or, does it matter as long as it fits the prop shaft snugly ?
and if it is pressed back in, should the holes be lined up ? or does it matter.
I should mention that it "appears" to have been run with little to no oil in the gear case and
it was half full of water when I drained it with maybe 4oz of oil.
