Home Forum Ask A Member Generator for 1959 35hp Gale Buccaneer
  • #186708
    mercuryspecialist
      Hello,
      We have a new old stock remanufactured OMC generator for sale.
      Thanks,
      Joe
      (770) 597-5992
      OMC-Generator-2
      OMC-Generator-1
      #186712
      mercuryspecialist
        OMC-Generator-2
        #186716
        David McFarland
          Thank you very much for these part diagrams, Frank. Extremely useful.
          David
          #186717
          David McFarland
            I am interested in purchasing this generator. I will call today.
            Best regards
            David
            #186721
            mercuryspecialist
              Hi David,
              You are welcomed to call, but as I see that you are from Canada, if you should like to e-mail, please do feel free. If you should write with your mail code, we can also quote mailing.
              Thank You,
              Joe
              info@fergusonpoolemarine.com
              #186865
              outbdnut2
                I have never seen a 1959 Gale Bucannes 35HP with electric start, other than the Sovreign model. The regular Buccaneer 35 was only pull starts as far as i am aware, but could be worng. That is why there would be no cogs on the flywheel for the generator drive. Any flywheel from a 1961 or earlier 25,35,40 should work. I likely have one if you need it. The generator bracket would need to have provisions for the gale style hood mount to be attached. I would have to look at some part numbers o be sure what motors could provide the correct bracket.
                Gale offered 35s with electric start every year they were made (1958-1960). Same for the 25s made before that. I have a 1958 35 with electric start. The model numbers had an E added in the middle of it.
                • This reply was modified 5 years, 5 months ago by outbdnut2.
                #186871
                David McFarland
                  Yes. The model number of my motor is 35DE12B
                  #186877
                    Actually, 35DE12B is a Sovereign. Has somebody removed the front doors from yours? I can understand why they would have. What a noisy motor they were!!
                    Gale-Buccaneer-Trim-Group
                    #186880
                    David McFarland
                      Well, then I guess I am wrong. Someone please help me with the exact model number. Mine is an electric start, 35 hp, 1959 Gale Buccaneer. The motor is in winter storage at the moment, so I am going on what I have noted in the past.
                      Thanks much.
                      #186890
                        Actually, it doesn’t make a whale of a difference if it is a Sovereign or regular Buccaneer. Pretty much the same thing. But now that we are “discussing” it, how did you determine it is a 1959? 1958 Buccaneer 35 electric start was similar except for the Sovereign trim. Also, are you sure it is a 35hp? Again, 25hp and 35hp are similar in many ways. Does yours have compression relief valves in cylinder head (35hp)? A running change in 1959 (35D11 vs 35D12) was the tilt lock on the stern bracket. 35D12 series had the type shown in the inset. 35D11 had the separate knob.
                        Pg-35E-8-Exhaust-Housing-and-Bracket
