Home Forum Ask A Member Getting and keeping my 3 hp. Evinrude running?
  • #274282
    overland
      I have a 3 hp. Lightwin Evirude that I got a couple years ago. Today I took it out and started it up. It took a long time to start, then finally did. But after a short while it no longer ran at higher speeds and shut down. I didn’t drain the gas over the winter though I did put in some gas additive. Is something plugged up? Why does it take so long to start when cold? What do I do? I’m open to all suggestions and remonstrance!
      #274283
      crosbyman
        fuel flow may be restricted from the tank’s inner filter  above  the valve ,
        the carb’s low speed circuit feeding fuel to the top drip holes maybe clogged…..
        first thing to do is clean  & rebuild the carb.. all orifices all passages and blowed with air pressure. (use a keyboard spray can if you have no compressor)
        check for sparks… coils maybe all cracked under the  fw.  points  can be usually cleaned and adjusted  but condensers  may be  bad .
        • replace the impeller if age or condition  is unknown
        all basic  oldies revival stuff   etc… etc…    see articles
        As  a AOMCI member  you could have  downloaded  yourself a copy of the 400 page +  johnson red book… it is worth it !! if you plan servicing oldies
        • MEMBERS ONLY tab
        • INNER SANCTUM tab
        • FIND LIBRARY
        • Find.. GARRY SPENCER’S DROP BOX
        • GO DOWN his list of files and find the RED Johnson Repair book file
        • Download and print ( a local print shop can print and collate the book for you…. the book covers 3hp JWs
        http://www.outboard-boat-motor-repair.com/Evinrude%203%20HP%20Lightwin%20Outboard%20Boat%20Motor/Evinrude%20Johnson%203%20HP%201952-
        1953-1967 Evinrude 3HP Litetwin Tune UP Project Ignition System Tune-Up | Outboard Boat Motor Repair (outboard-boat-motor-repair.com)
        Outboard Motor Carburetor  Repai (leeroysramblings.com)
        http://www.leeroysramblings.com/johnson_magneto.htm
        #274289
        overland
          Thank you for the excellent advice.
          #274291
          wedgie
            Check Crosbymans links for the details .
            My first thought is cracked coils. Almost certain they are cracked if original. You should also clean the fuel system and check impeller and gear oil .
            #274296
            crosbyman
              Dang… forgot the gear oil  🙂 …. and always use new nylon washers
              #274346
              lindy46
                Was it running good last year? What maintenance have you performed on the motor in the 2 years you’ve had it? Have you checked compression? All good advice above. If those motors have compression, spark and gas they will start easy,  run great and idle down to a putt-put-putt. I’ve had many and they are great motors and practically bullet – proof.
