Home Forum Ask A Member Grounding spark plugs
  • #55327
    wagemaker
      Thanks to all who responded. I will be more attentive to grounding. I plan to make a few wires as per Mumbles photo and keep them with the compression tester.
      #55378
        Mumbles, did you dismantle some old plugs to get those parts?
        Kirk
        #55379
          No, they are solid brass rod which has been turned on the one end and drilled on the other for soldering the wire on. The groove was to make it snap into the spark plug terminal. A piece of solid wire, with the end bent back on itself would probably work to.
          #55385
            I figured you made those. Nice job. Of course another set of alligator clips would work too.
            #55434
            bob-d
              Mumbles, what was the diameter of the brass rod, you started with?
              Thanks.
              #55447
                quote Bob D:
                Thanks.
                1/4"
