Home › Forum › Ask A Member › Happiness is:
- This topic has 13 replies, 12 voices, and was last updated 9 years, 10 months ago by
mr-asa.
April 7, 2015 at 4:34 am #1125
Clearing the garage out so I can actually use it, then having (almost) everything primered and ready for paint.
What stage of project got you feeling satisfied recently?
And because it has been running through my head all day…
"Bang bang, shoot shoot"April 7, 2015 at 1:55 pm #13470getting magneto back together with good spark on both cylinders the first time. Ready to prime lower unit on another project now too.
DougDoug
turned off?April 7, 2015 at 2:06 pm #134712 OMC 10hp blocks all cleaned up and ready for rebuilds. The QD19 is getting conn. rod with bearing upgrade. The 1962 is a fresh/used block, the original block is junk.
April 7, 2015 at 2:15 pm #13472Successfully removing the internal rust from some pressure tanks!
The first step in restoring some tanks is completed!
April 7, 2015 at 3:00 pm #13479Room for more motors … 😀
April 7, 2015 at 5:10 pm #13491Picking up a Golden Pennant-styled Corsair by Scott Atwater for 30.00.
Then getting it home to find out my 5hp Corsair was actually a 10hp!
Aha! That’s why it seemed so heavy!
Greg
April 7, 2015 at 6:33 pm #13500Made some great progress on a 77 15hp and a 40hp Bigtwin gearcase last weekend.
April 7, 2015 at 7:08 pm #13504Having motors start on the 2nd or 3rd pull after all the work you put into them. Picked up these 2 last year, both not running at the time and didn’t get around to working on them until last month. Went through the ignitions, carbs, lower units, and broken handle assembly on the Evinrude. Caught a nice day last week and put ’em in water and both started real easy and smoothed out real nice after the carbs were dialed in. That made me real happy!
photo uploadApril 7, 2015 at 10:38 pm #13509quote Garry in Tampa:Room for more motors … 😀Little lady found a home in foreclosure that is on about 2 acres, and has a hobby shop on the property. The shop is big enough for 5-6 cars and comes with a hydraulic lift in it already.
I drove by it and liked it until the train went past just past the back yard.quote Steve D:Having motors start on the 2nd or 3rd pull after all the work you put into them. Picked up these 2 last year, both not running at the time and didn’t get around to working on them until last month. Went through the ignitions, carbs, lower units, and broken handle assembly on the Evinrude. Caught a nice day last week and put ’em in water and both started real easy and smoothed out real nice after the carbs were dialed in. That made me real happy!
photo uploadI have a 5.5HP that I need to check out. It runs, but only at WOT. I’m thinking there’s a carb issue.
I like the updates, guys!
April 8, 2015 at 3:28 am #13525 -
