Home Forum Ask A Member Hard starting opposed twin
Viewing 6 posts - 21 through 26 (of 26 total)
  • #17236
      Not likely your issue Adam, but I OVERCOATED one of those floats once, the extra weight of the coating made it too heavy, and flooded. Would not totally seat. Just a thought.
      If you were closer we could try another carb from one of mine? If it continues to boggle you though, I could mail you one to try to rule that out.
      #17278
        • This reply was modified 6 years, 5 months ago by Tubs.
        • This reply was modified 4 years, 2 months ago by Tubs.
        #17290
          That is a great idea Tubs, so you can see what is going on before putting on the cap and installing. Simple, but effective!
          #17455
          adam1961
            That is a nice setup for testing the needle/seat.
            I pulled the cap off the float chamber and looked at the float. It does float, but does not seem the be pulling up on the needle very hard at all. When I coated the float, I used model airplane dope and brushed on a thin coating. The cork seemed to be in decent condition.
            is the best course of action to set the float slightly lower on the needle so that it puts more pressure on the seat, or to replace the float? Has anyone found a good source for material to make replacements?
            Adam
            #17456
            RICHARD A. WHITE
              Sure looks like a Speedster carb…..LOL
              classicomctools@gmail.com
              #17477
