Home Forum Ask A Member HD25 shear pin size
  • #166269
    Rick Robbins
      What would be the shear pin size for 1950 HD25? Are some available, or do most make them from rod stock?
      Rick
      #166274
        a brass bolt shaft or rod of the proper diameter cut to the proper length should do …
        #166275
          Part number is 004372. But I can’t find my size chart. I’m guessing (assuming) that they are stainless steel, since the motor has a rubber shock absorber ring in the propeller. Most of us make our own.
          • This reply was modified 7 years ago by frankr.
          #166281
          Rick Robbins
            Looks like a # 6-32 brass machine screw i” long with the head cut off would do the trick.
            Thanks for the replies!
            #166283
            rmhxruss
              The correct current part number is 043072 old 43-72. Shows $2.00
              #166285
                Johnson-Drive-Pin-Chart
                  Shear-Pin-Chart2
                  Shear-Pin-Chart3
                    5/32″ appears to be correct.
                    • This reply was modified 7 years ago by Buccaneer.
                    #166302
                    Rick Robbins
                      WOW, thanks alot for this chart! Much appreciated.
                      #179183
                      Thomas Otto
                        I was toying around with the idea of using a drill bit, though that would rust over time and is highly inflexible which may cause other things to fail if something goes wrong. In any case, the drill bit that fit the best is a 1/8″, if that helps. I will attempt to find some brass rod stock and cut one to length, or I may go the brass screw route that was suggested above.
                        otto_my_way
