Home Forum Ask A Member Head Bolt Replacement
  • #274412
    crabb
      I need to replace the head gasket on my 65 Evinrude 3602E. The gasket itself is pretty affordable, but I’m looking at the head bolts and they’re $10 a pop on Marine Engine. Ebay is not much better. The part number is 0306418, but is there a spec or equivalent part I can use to avoid $60 in head bolts? I am assuming they’re torque to yield so I probably don’t want to reuse.
      Thanks,
      Dan
      #274414
        I bought some of those high dollar head bolts from Marine Engine a few years ago and what they sent me was just a Grade 5 bolt with a yellow zinc coating.   I sent them back and now all I use on any project is Grade 5 zinc plated bolts from the hardware store.    Never had any problem with that approach.   They are not torque to yield bolts like you’d find in the cylinder heads on your truck.
        #274419
          The bolts originally installed back then probably were cadmium plated.  You won’t find cad plated bolts anymore.  In addition, OMC was notorious for using odd length bolts or odd thread lengths.  So, be careful when shopping at the hardware store.
          Advice from here is unless you have good reason not to, just reuse the old bolts.  They might be better than what you buy now.  And no, they are not torque yield.
          #274458
          fleetwin
            Listen to Frank, no need to replace those head bolts unless obviously damaged.  The head bolt torque is only 60-80inch pounds which won’t stress the bolts at all.
            #274470
            crabb
              Thanks everyone!
