Home Forum Ask A Member Head gasket advice
  • #291376
    LARRY CATON
      Do I need to coat this gasket in oil or dip it in mineral spirits before installing it?
      I read that procedure in a service manual, but elsewhere I read that updated replacement gaskets have a shiny coating and don’t need any treatment.
      I got this one on eBay.  It doesn’t look shiny to me.
      Thoughts?
      1956 Johnson 15 Hp, FD-10
      1957 Johnson 5.5 Hp, CD-14
      1958 Johnson 5.5 Hp, CD-15
      #291378
        I dont see amy shine
        #291382
        labrador-guy
          It does not look shiny to me either!   What I like to do is make sure both surfaces are clean.  You can tape a piece of sand paper to a flat surface such as a piece of glass or a counter top.  Squirt some water or wd40 on the sand paper and rub the cylinder head on it.  Make circular motions and keep the head as flat as possible.  It will clean and flatten the surface quickly.  A new head gasket never needs sealer but as used one might.  Use some 220 wet and dry sandpaper.
          dale
