Home Forum Ask A Member Head Gasket Material
  • #271106
      Bucc and Bob, did either of the gasket materials you referenced have a metal core? I have ( from NAPA) some material that should be ideal for head gaskets called ProRamic 2499 from FelPro. It’s rated for exhaust manifolds and has a thin steel core layer with heat resistant fiber layer on each side. It’s 0.064 thick. The problem is that you will not be able to cut it with a knife, a good punch will do the bolt holes, Cutting the shapes necessities, sandwiching between two plywood/ hardboard sheets and sawing, jig saw or hole saw.
      I have not personally used it for a head gasket, but looks to be ideal.
      Joe
      Joe, my gasket material did not have a steel core.
      I did read comments about some material that does
      have the steel core, and some said, as you,
      that it’s hard to cut, and also that the material tended
      to separate from the steel core and crumble.
      I’ve had problems using hole punches on thick, crumbly
      material before, especially if the hole is close to an edge.
      Robert Wight
        The Cometic material I used did not have a metal core either.   I seem to recall seeing that Fel-Pro 2499 product – it would probably work fine but I was concerned about how easy or hard it would be to cut.   Guess I could try it.
        #271112
        wedgie
          This was for a JW or Lightwin .Using metal core gasket material. Really hard to cut by hand.
          Photocopy old gasket on desktop printer. Spray glue on to   3/4 inch  plywood. If you don’t have a gasket you can copy the cylinder cover.  just pack towels around to keep ambient light out.
          Screw two pieces of plywood together with stencil on top.
          Use drill press to keep everything square.
          I used a Forstner bit to cut the cylinder holes. Spun it in reverse at first , then in forward thinking it would cut cleaner. Used drill bits, and hole punches for all the water passages and bolt holes. I’m guessing a decent hole saw of the correct size will work too on cylinders.
          Sandwich gasket material between plywood and locate opposite corners with bolts and nuts to hold the gasket firmly. Then do the rest of bolt holes and bolt them together before cutting out the cylinders with the Forstner.
          Maybe a router would work too.
          thumbnail_20230112_162117
          thumbnail_processed-b992f481-010b-48fb-8281-169a0192a458_eGlXTvFn
          thumbnail_processed-cabc5425-dc7c-4bd4-b840-f405c9a76d43_QVKaEBKY
          thumbnail_20230113_120229
          • This reply was modified 2 years ago by Mumbles.
          #271117
            Wedgie, Looks like it was a lot of work, but turned out okay.
            I would have thought someone would be supplying head gaskets for Lightwins
            yet, seeing how there’s so popular.
              To conclude my “Head Gasket” docu-drama series,
              I trimmed the OD of the gasket this morning.
              The thought came to me laying in bed last night,
              pondering if I might have a Dremel bit that would
              carve away the excess gasket.
              I found a “needle” like rotary burr, and it made fast
              work eating the gasket as I followed around the head.
              I then followed up with a tiny drum sander Dremel
              bit to smooth off the fuzzies.
              Of course, I wouldn’t recommend this method if
              you had a fresh painted motor!
              DSCN5797
              DSCN5798
              DSCN5799
              wedgie
                Of course I could buy one, but where’s the challenge in that ?  Actually,  I’m really cheap 😉
                I had the time and the materials on hand so I figured it’s be worth my while to make a few and use up the gasket material I had. Kind of satisfying to figure out the process  . I also have at least a dozen  JW ‘s and  Lightwins, so worth it to make this jig.
                Great idea using the Dremel to fine tune things !
                #271139
                  I have attempted to make one gasket out of this material. Whish I had seen
                  your procedure using the plywood first. Will definitely try it if a attempt to
                  make another. How did you remove the excess material from the outside of
                  the gasket.
                  A "Boat House Repair" is one that done without having tools or the skills to do it properly.
                  #271173
                  Bob Lowden
                    I got these hole punches from my dad.  Most were commercially made.  Ones at top were made by dad on a grinding wheel.  The small gaskets at side were made to place against old copper and fiber washers on carb bolts of my Elto Ruddertwin.  Cork washer is for the carb needle nut.  Took two to get correct thickness. Outside and inside holes were made using two different sizes.  Tip: make large piece first.  Aids in centering inside hole.  Samples shown were my first attempts.  Believe such punches are still available.
                    Hole-Punches-3
                    #271202
                    wedgie
                      Tubs,
                      I used sharp tin snips to whittle away the outside. I’m not too concerned with appearances so didn’t spend much effort making it pretty.
                      The worst thing about this method is  dulling of the Forstner bit.
                      #271236
                      crosbyman
                        Canada Member - 2 Years
                        a router with a straight  cutting bit and a template (over the  gasket material)  to guide the roller bearing would make   neat sharp edges.
